Technical  Horn Problems
Stule12
I have a punto 1.4 GBT 62 plate and the horn has given up. I changed the indicator stalks a couple of years ago so hoping its not at the steering wheel end so thought I would check elsewhere first.
Arch liner screws are rusted up so waiting on some replacements before i drill them out and drop the bumper off and check the voltage on the horn.
In the meantime I thought I'd check the fuse and the relay. All the wiring diagrams I can uncover show a different fuse box with a fuse and relay not just a single fuse.
The fuse box is as below and think F10 is the horn fuse but no relay?
Anyone got access the to relevant wiring diagram or can offer any advice.
Model
1.4 BGT
2012
Mileage
107
You'd be better off checking the voltage on the horn. Because usually there is their problem. Horn contacts and connected cables contacts oxidized.
Let us know where the problem was, after you find it.
Thankyou for the assistance.
Wiring diagram allowed me to check the relay which was working fine so directed me to the horn. As suggested unplugged the connections and put them back together and its back in action.
Not the most accessible place to get to but not so bad when you are sure its the problem.
Thanks again.
