Have an issue wth the hill holder operation - the hill holder warning light occassionally illuminates for a few seconds, other times it can come on for 10 minutes, and then the light goes off again. Acceleration, braking and steering inputs have no influence on when its on or off. When the light is off the hill holder does not function anyway.
Thought this might in some way be linked to the replacement of the engine ecu recently, but the other half says she has seen it flicker from time to time before then, so i guess that one's out. When the ecu failed, the car was towed on a trolley by the AA, so back wheels free rotating, and front stationary on the trolley - when i first looked at the car after that, the hill holder and engine management lights were permanently illuminated and no codes came up on the OBD other than the throttle position (ecu) fault.
Does anyone know if there are any specific OBD fault codes for the hill holder system ?
Any idea how it operates ? - presumably theres a tilt sensor somewhere ?
Thanks.
Thanks.
