Ascending a steep hill, the engine judders as if starved of fuel. I have checked for vacuum leaks and found that the vacuum pipe union on the back of the air box had been snapped off. plastic welded it back on hoping that it would solve the issue, as there was oil around to top of the carb. Thinking it was drawing oil through the carb creating a dirty mixture. Test drove today and found that it is still juddering, albeit, intermittently going up hill as if in the wrong gear. I am yet to pull out the spark plugs to check. Oil level is correct. No head gasket issues.
