Technical  High revs
Technical  High revs
Multiporter
Hi all, my multi (1.6 petrol)2001 has an annoying habit of high engine revs. On start up cold it idles at about 2000 rpm then settles a bit to about 1500 rpm, after that it either settles to a nice 5/600 rpm or goes crazy up to 2500 rpm, blipping the throttle doesn't help, but sometimes stopping the engine and restarting it will settle it.
I read about cleaning the white connectors but think that only applies to diesels. The throttle cable seems fine and lubricated.
Any pointers please to where I should look first. Many thanks
Could well be your throttle position sensor. I do not know the 1.6 multipla but have worked on many a petrol and generally these are on the throttle body where your throttle cable connects. It is a variable resistor and the contacts can get dirty. Otherwise your MAF could be sending a false signal to the ECU but I would start with the TPS.
