Technical  High Pitched sound
psychofox
Legend
North London
Hi guys,
My Mk 1 is making a high pitched sound (which i can only describe as kind of like when you hit the triangle musical instrument - but louder), when I accelerate. its not all the time, but i do notice it in low gears.
The sound sounds like it is coming from the right side of the drivers side in front.
Any idea what is causing this?
IF its the timing gear.. it would do it most of the time..
Well, that throws that idea out of the window :bang:
Thinking about it, the sound is like that high pitched sound that made made you rub you finger around a wet glass....if that helps?
Is it only when under load ????? im thinking maybe its "Pinking" which would be caused by a Lean mixture or timing out. (Just a thought)
Ok.
Sounding like its NOT a traditional rotating noise.
Most things that can slip..distort.. under power will be pretty stable at that speed.
That's a good thing...right?
I think its due a service, will take it to the garage on Saturday and tell them about it. Funny thing is, drove it last night and the sound didn't happen :confused:
So about two weeks ago i get the car serviced, sound goes away. I drove the car last night and the sound returned :bang:
