Technical  Help
Technical  Help
Sri Lanka Fiat
I had a problem when driving the car it’s difficult to put gear, so I replaced clutch plate and pleasure plate. Now gear issue is over but the car is very slow and it’s doesn’t pick up properly, difficult to drive drive. It would be appreciated if anybody could advise me.:confused:
Thanks.
Thanks for your kind reply. My car is a petrol one [Fiat Uno IE 1.0 cc, 1995]. The car is original fuel injector but my car has converted to a curbulature[Uno 45 crab]
My mechanical guy believe its problem with pleasure plate. still car not moving properly.
Thanks,
Exactly, yes, mechanic guessed the problem may be pressure plate.
We changed a new pressure plate and clutch plate. But after my car got completely mess. She doesn’t pick up very well. Only the accelerator racing but car not moves properly.
As you mentioned the engine dose start and idle.
Harsha
Thanks for the reply I changed a new silencer then repaired the curb, after changed an original Italy pressure plate. Now my problem is over. But my battery is not charging when the car running.
Please let me know what is the right margin to tune the carb?
Thanks.
