HELP!?
HELP!?
J
JTD
Ive just driven 10mins down the road went into the shop for 10minutes and now my car wont start! Im sat posting from my phone.
Its a JTD bravo Y reg. Its been runing fine and not given me anything to worry about until now! bar a bit of smoke out the back if i put me foot down.
Its turnin so its not the battery. Its jus not firing up.
There is fuel in it, unless the gauge is lying to me!
Its started. I kept pumpin the accelorator while i had the key turned, took about 10seconds though.
Has always started straight away first go in the past.
Where there any lights on the dash ????
When was the last time you changed diesel filter ???
Members Site
was the heater coil light showing in the dash when you turned the ignition on??? if not.
Check your small 30 amp fuse in the fuse box in the engine bay its right at tghe front,check it for being manky etc,if it is change it.
This happend to me.
Scotty.
