S
Smee
ok car problems.
1) at speed i can hear a rattle coming from wat sounds like my side front suspension area. it a high pitch rattle. its like holding a kiddies tonka toy and shaking it sound. i have had new suspesion, drop link, and lower arms and all bushes changes in the last 5 months. any ideas?
2) when i start my car its makes a really scary sound. sounds like a belt whine / squeak. it does this untill the car has warmed up. then its goes away and leaves the normal tappet sound. the car is over die a service. which will be going in just after xmas. oil change, plugs, (had new leads 5 months ago), gear box oil change, u know the usual **** except touching the filter.
to tell the truth the whole car need a tune up. its going on a rolling road soon so im sure they will tell me its under powering. wat kinda things can be adjusted to run correctly. can the timing be out? could it be under fueling? maybe some of my sencors and on there way on something. i know my exhasut has a leak. but it sounds rough.
Smee
http://www.visionstyling.co.uk for ALL your car needs!!!
Smee
