Technical help
Technical help
Status
Not open for further replies.
josh sawbridge
hi iv got a cinq 899cc engine and want to put a 1.2 8v punto engine in it any advice at all would be reli aprreciated thanks josh btw some really nyc cars on here
well the easiest thing to do would be get a sporting cinq because all you need to change is the engine, all wiring is exactly the same and you can keep the 1.1 ecu as it will correct it self for the 1.2. but other wise im not sure i think u might need to change some of the engine mounts, get ither a 1.1 sporting or 1.2 ecu n u might need the wireing loom but im not 100% sure so hope this helps.
cheers for help ill defo have to check with insurance first dnt want it to expensive lol
very gd point seems like my engine swap my be put on hold for while ill need a new sporting gearbox drive shaft gear stickengine bay loom and more :(
Status
