Technical Help with parts ID
kevalino
Corfu, Greece.
I have a Mark2 Punto and live on Corfu, Greece. On the driver's door - the part that stops the door from opening too far has broken. My local attempts to get it repaired have failed. I have been back to the garage 6 times. Could anyone tell me the name of this part or the part number, please, so that I can make an online search.
I have spent hours searching already and it is impossible if you don't know the name or part number.
Thank you. Kev.
Hi
I had a quick look on eper
Home
Print
Help
Basket
Search
DVD Rel.20
@import url('styles/domToolTip.css');Fiat \ PUNTO \ 2U PUNTO FL.'03 (2003....) \ 701 MOBILE PARTS AND GLASS \ 70129/00 SIDE FRONT DOORS Current vehicle data: GD
n. 1/5
subcategory: 70129/00 - SIDE FRONT DOORS (Tab:1/5)compatibility: None
naread.exe
@import url('styles/domToolTip.css');Prod. Code Fur. descr. Comp. Modif. Qty N. C. C. R. 1 DOOR 46520373 DS P3 C6846 01 51744976 DS P3 D6846 01 46520374 SN P3 C6846 01 51744977 SN P3 D6846 01 46790060 DS P5 C6846 01 51744978 DS P5 D6846 01 46790061 SN P5 C6846 01 51744979 SN P5 D6846 01 2 METAL LINING 95460211 DS P3 01 95460212 SN P3 01 95460207 DS P5 01 95460208 SN P5 01 3 HINGE 46538081 DS 01 46538082 SN 01 4 HINGE 46835226 DS 01 46835130 SN 01 5 SCREW 7658843 04 6 HINGE 46530597 DS 01 46530598 SN 01 7 HINGE 7792767 DS 01 7792768 SN 01 8 SHIM 46834462 04 9 SCREW 7769300 08 10 SCREW 46754352 04 11 SCREW 51716377 04 12 PLUG 51711860 DIAM 18 02 13 ROD 51754187 P3 02 51754186 P5 02 14 PIN 51712110 D6846 02 15 PLUG 51746230 D6846 02
1/5
naread.exe
70129/00 - 1 2/5
naread.exe
70129/00 - 2 3/5
naread.exe
70129/00 - 3 4/5
naread.exe
70129/00 - 4 5/5
naread.exe
70129/00 - 5
n. 1/5 : 70129/00 - SIDE FRONT DOORS
Fiat
Eper
Eper
Eper
Eper Fiat Alfa Romeo Lancia Fiat - Commercial Vehicles
found this part.
Thank you. Kev.
If you look up the top of the forum we have eper
http://eper.fiatforum.com/
you can usually work your way to the part you want just by the graphics
have a play with it as its handy to know how to use and access :)
Thank you all so much - I will find it from the help above. Unfortunately, the part has actually snapped. The "hex" screws kept coming loose and then I took it in for service and when I collected it the part was broken.
I wouldn't trust the guy at Fiat ΚΙΝΗΣΗ in Kerkyra. I went there for a small air-conditioning drain pipe last year. He told me it wasn't available seperately and that I had to buy the complete air-conditioning unit for 1700 EUR.
I printed the page from ePER to show him. He ordered the pipe for 7 EUR.
Thanks Davren. I have been trying to source the part in the UK but things take ages to get here. After getting the info from the site and following your advice, I have printed it and will take it to the dealers in town tomorrow.
