C calagahan New member Joined Aug 1, 2006 Messages 5 Points 2 Location hazel grove Jun 13, 2007 #1 i'm having problems with my 1600 elx on a 51 plate its running on 2 cylinders. it looked like the ignition coil pack. i have fitted a new 1 but its still the same. no spark on cylinders 2 and 3. any ideas please
T14086 Patron member Written a guide Joined Sep 12, 2004 Messages 39,826 Points 7,252 Location Preston Jun 13, 2007 #2 if plugs/leads/coil definately ok then it will be wiring/ecu fault.... this might help..... https://www.fiatforum.com/punto-guides/52068-punto-coil-ecu-checks.html
OP OP C calagahan New member Joined Aug 1, 2006 Messages 5 Points 2 Location hazel grove Jun 16, 2007 #3 The ECU has water damage.... Looks like water has been dripping on it from the bulkhead for sometime and the contacts had become corrosive. I fitted a new 1 today and everything is ok.
