Hi Folks, My girlfriends car is revving itself even after ignition key taken out and engine bellowing with white smoke, any ideas?
To update.
The car did indeed use the oil and on inspection by the mechanic(who did the turbo) concluded that the engine was terminally damaged.
The mechanic was a chap doing jobs on the fly, both him and the company that supplied the recon turbo blamed each other so was screwed.
Managed to get a full(injectors/turbo etc) second hand engine for 900 delivered that had done 21000 miles(current engine had done 118000) and fitted for £460.
But tbf she runs lovely.![]()
You seem very laid back about it all. I'd be on the war path if I'd lost out to the tune of £1360 and it wasn't my fault.
Me too. If the seals were faulty in the turbo, the fitting of it will not affect that, so the fitter would not be at fault. Turbo supplier should be contributing most of repair cost. Fitter could supply his labour free.
Bit of blackmail, would the fitter appreciate his employer becoming aware?
