C
Conrad
Let me explain the symptoms and then ask the questions...This is a MK2 115 Bravo
Quite frequently my dash suffers from electrical drop outs.
What isn't affected are all warning/info lights (handbrake, mainbean, abs, indicators etc), Fuel guage, Temp guage.
What is affected; Speedo, Rev counter, Milage display
Symptoms: The Speedo dies completely; the Rev counter either dies completely or operates erratically; the LCD milage display is either dim (ie LCD bits are grey, not black, it is still backlit), flashes ramdomly or flickers very quickly, sometimes appearing to flicker in time with the enigine revs.
During these problems the odometer and the trip milage do not update as I drive along.
Questions
I have had the dash out and reseated the two connectors at the back of it (White and Yellow). However, does anyone know what information is passed along which cable?
Could this actually be an ECU fault or ecu connector fault, hence the odometer not changing during the problem and it not 'catching up' with the increased milage when the problem stops?
And finally, does anyone know just where to hit the dash to solve this problem?
Hoping someone out there can help
Conrad
Questions
Conrad
