I need to remove the valve cover on my 1997 B. I already have removed the coil cover. If anyone knows the following I would appreciate some advice:
1. Once I remove the two bolts holding in each coil do they just pull out? Do I need to by a new gasket of some sort or can they just be put back in when I refit the cover?
2. The valve cover is help down with 8 obvious bolts. If I remove these will it just lift off? Is there another screw that goes through the plastic timing belt cover into the valve cover? (It is a little tight to see in there)
3. Is the rubber gasket under the valve cover normally reuseable or should I plan on having to get a new one?
Just looking for a little guidance before I remove the thing. As you may have guessed I plan to bead blast it and paint it.
Thanks for your help
BR
BR
