Technical Help! Panda running on 3 cylinders!
MikeBall
Haverfordwest
Hi, would appreciate any help or ideas. Our little 2008 1.2 dynamic is only running on 3 cylinders. I've done plugs, ht leads, coil packs, compression test, checked drainage channels below windscreen for water, checked ECU plug for dirt and visually checked as much wiring as possible still no joy. Any ideas would be appreciated
Hi
Soak the exhaust manifold.. So it goes Dark,
Run the engine see which branch lightens last
Then swap coils around.. See what moves 😉
A poor connection is a fair possibility.. 🤔
Pull a HT lead off one at a time
Which one makes no difference is the one that's not firing
Are you sure it's a one cylinder misfire
What was the compress result
Post at a video of the exhaust sound might be helpful
Sorry it's a long list we need to start to narrow it down
Please don't change any more parts in the hope of fixing it
Slightly different coil pack on mine, yours will be two on the right of the engne
Hi
Hi, have swapped coils around, and ht leads, not running on number one cylinder, compression about 160psi but definitely spark at spark plug.
Definitely not firing on number one cylinder, compression 160psi. and there's a good spark at spark plug. Swapped all the leads and plugs around made no difference. I've insulated the ht leads now with high quality insulation tape just incase they are tracking.
So what happens if you run the car with number HT lead unplugged and plugged
Is there a difference in engine idle
160psi should fire but it's well down
Are the other cylinders the same
Makes no difference with ht leads in or out. Compression tested by holding tester bar in because it wouldn't screw in, I was under the impression 160 was about right
210 plus on the euro 5 engine which is a slightly higher compression ratio
Below 145 alarm bells would be ringing
160 is okay ish, crank speed, temperature, oil grade, if the car been stood, just run, throttle open or closed, gauge accuracy and so
I use the cone it's quicker you do have to push down hard though
I call it good as 145 is good enough to fire and you are past that
Do you have a bidirectional scantool where you can command the injector to open
If so command cylinder one to open and close
You should hear it click
It will not tell you if its working but will tel you ecu and wiring is fine
I don't, read something about a sensor in the inlet manifold, are there any sensors that would cause this fault
Lots of sensors cause a random misfire
No sensor causes one cylinder not to fire
Compression, spark at the right time, the right amount of fuil and air
Because it sparks in the open does not mean it will spark under compression, You have swapped the plugs over to see if the fault follows the plug
Any history to how it failed
Gradual
After swapping a part
Overheating
Does it fail only at lower revs, how does it drive
Gradual
Overheating
Yes, have swapped plugs and leads round so many times! It played up a few times then cleared, now only on 3 all the time. Drives ok, quite smooth really!!
Mmmmm
Shouldn't
They idle quite well on 3 cylinders and shake a bit on 2 clinders
But it should be quite noticeable on any gradients
The Big concern is lack of servicing can overstress the Spark Driver Board
So the one coil is getting no signal to produce the High Tension 🤔
Swapping coils around should prove / disprove that..
Moving the dead cylinder with a different supply
What state were the original spark plugs?
Yeah, have swapped coils packs around, no difference. Spark plugs all look good.
I have swapped the coil packs around, no difference. Spark plugs looked good
Plugs 1&4 and 2&3 batch fire, and you have checked firing is correct.
Compression test is the same for all cylinders.
Injection is sequential and you need to check if injector 1 is operating as it is not misfiring.
