pauly boi 1989
- Joined
- Sep 22, 2010
- Messages
- 7
- Points
- 2
Hi all im in need of help
My daughters car has broken down, im a mechanic and looking for a bit of advise before i throw money away, so its a 2011 500 1.2 driving along and lost all power cuts out and no restart, once recovered i takes a look, eml flashing on the dash, cranks but no start, plugged in with, delphi,autocom and wow no communication to any system, disconnected battery and checked for the common bad earths nothing wrong so re connected battery, first time the ignition is on the eml stays on solid and i can communicate, only codes are p1300 crank sensor relearn and p1325 knock sensor circuit fault. Tried to delete and they wont, tried to start and still nothing, left ignition on while nosing at both sensors and the eml had stopped flashing, tried to start and it and it did run for about a minute then cut out, back to the start again with eml flashing but know i can still read faults, replaced both crank sensor and knock sensor and wiring checked but still having the issue with non start, so know i thinking possible engine ecu
Has anyone had this issue before tia
- Model
- 500
- Year
- 2011
- Mileage
- 82000
