2013 I doubt is the latest blueandme software unless someone did update your car previously as the updates went on till mid 2015 for the blueandme system.
If your current system is at least working you should be able to press the lower outer LEFT steering wheel button which will either be a windows icon or a mouth/voice icon with ignition ON you should get a message from the radio speakers to 'MAKE a SELECTION' then it will state options which should be 'settings' 'delete users' or delete all'.......................I always just 'delete all' as it clears from the cars memory any previous user or device that has been previously paired up.
So if your car is set to understand ENGLISH you only have to speak into the front clearly the voice command.........if you have a strong Scottish or Irish accent
I don't know as I read some struggle..........
So if the radio does not even speak to you then you have some other problems.......
To check what level software you have I need to see your BMConfig file and upload to the official blueandme website to see what updates are needed.
The very latest and no longer any updates available after 2015 but the very latest is V10 2nd Generation and we can update your car to this level providing currently all the items are working.......this means a working blueMe module and a working USB port........appears your USB port is OK so if the BMConfig file comes back showing a BMADDRESS in the script line then we can update.........
You will need to PM me with your email address as I need to send you the extraction files to get at your current BMConfig file......you will need a 2GB USB flash memory formatted to FAT32 (FAT32 is important).........download the files and place in cars USB and the BMConfig file will be placed onto the USB stick which you need to send me back.
Older cars this can take sometimes 3 updates required as you cannot go straight from 5.4 to V10 but I would suspect your car at 2013 would at least be 5.6 so should just take a single operation to get updated.
I will send the files via wetransfer.com and you can send the BMConfig file back by email as it is just a small file. This is referred to as stage 1 and does not alter anything on your car just reads the current configuration.
Also one further step is if you want to interface a TomTom2 sat nav as this will require a further line code change...........as the earlier Magneti MarelliMAP and TomTomONE sat navs Fiat Chrysler used are really outdated then I suggest you add this update too at the same time.
I will await your PM info
BYE
