Technical Help needed: 2006 Punto HGT ECU wiring diagram
z0n3
I tried searching but couldn't find any information on this.
Does anyone have the 1.8L petrol Punto HGT ECU wiring diagram?
This would be the Hitachi ECU.
Thanks in Advance.
Cheers,
hi mate i would be very gratful if you can help me out. i am having problems starting prombles with my car down to my ECU so i have been told. from my 1.8 hgt fiat punto.
is the hitachi 12v? the rite ECU? im not sure if i have found the rite ECU. also can these be replaced by a plug in and play model or not?
Why do you think the ECU is dead? They are usually very reliable.
Have you checked the cam and crank sensors and are you using an ignition key with the correct transponder chip for the ECU - they are matched for life
