HELP ME! Trying to remove rear bumper!
T
Tommy K
Right i've un-done all the visual screws and bolts.. but it seems to be stuck round the corners under the lights.. is there any botls holding it theree. if so where.. if not.. dou just tug at it...
Need help asap please!!! :)
As far as i remember, youve got 3 bolts running along the very top of the bumper, just under the boot sticky-out bit
Then, underneath the bumper there are 3 or 4 of the same bolts, which you will be able to see quite clearly,
Then the bumper is screwed to the wheel arches using little screws, 3 on either side i think.
Mine bumper pretty much fell off with all the bolts out, but then again it had been off before to fit the tow bar???
KeithR
you need to undo the platic **** shield in each arch, pull these forward and you will find 1 bolt on either side holding the bumper into the rear quarters (they are 10mm) once they are undone you should have got them all..
as stated, three on top of the bumper, 3 or 4 on bottom, three screws on sides (these 3 will allow you access to the bolts i mentioned above!)
Paul R
cheers guys... yes paul i found them..
was gonna go for the BUZZ tecnique and just load the rear up with so much weight it just falls off up the road :)
It's now off, but i think my tow bar wont fit anyhow :(
Got it off :)
