General Help! I'm desperate for a Cinq fuel filler pipe
ChrisFiat
York
Hi all,
I'm in the process of getting my 1998 Cinquecento Sporting on the road after it has been laid up for 3 years or so.
Initially struggled to find a pair of headlights, now those are sorted (LHD versions with RHD lenses), the car passed it's MoT with no advisories.
However, upon putting £20 into the tank, it seems there are a couple of holes in the pipe that connects the fuel filler to the tank causing a pretty bad leak. I've searched high and low for one and not had any luck.
The car is now stuck at the garage and I'm under a bit of pressure to find one as mine cannot be repaired - can anyone help me out? It would be massively appreciated.
Thanks!
OP
OP
C
ChrisFiat
York
Thanks for the suggestion, I think that would be the best way to go.
I've checked out Demon Tweeks and they have an option to choose the internal diameter of the hose plus it's length, so that should do the job.
All I need to do is remove the filler assembly to get the measurements!
Thanks again, Chris
