Hi. First post, and I warn you - am renowned for a waffle
So, I have a 58 plate 1.6 multi-jet diesel (67k miles), and it started to regularly go into limp mode, sometimes at speed (which can be scary!)
I took it to my local garage and they started to talk about injector issue and large sums of money, so upon recommendation took it to another garage and they suggested I take the car to a diesel specialist, which I did.
After a few days of investigations, they took the injectors out and found that at least one of them was being very generous with the amount if fuel it was allowing through and the sump was more diesel than oil! So after not a small sum of money being paid out, I had four new injectors fitted, new oil and filter and an exhaust re-gen done.
Picked up the car on Friday evening and drove it home - seemed to be back to itself so was feeling much more positive - had been driving it at 2,000 RPM or less as this seemed to stop the car going into limp mode, so was great to be able to put my foot down again. Saturday morning, was planning on a drive down to South-End (as was suggested by the garage I give it a good run) and so set off on the M25...three miles in and the same issue - car drops into limp mode, so pull-over, and re-start the engine and it's off again - again, kept the RPM down as low as I could and made it there (over an hour's drive at an average of 50-60MPH) and later the same day, home again - only repeated the issue when I had to pull away on a very steep hill and couldn't avoid giving it lots of revs to get me moving.
I spoke to the garage this morning and they feel it needs another re-gen (forced?) as the amount of soot cause by the dumping of excess fuel into the exhaust/sump is most likely the cause - would the drive on Saturday not have caused a re-gen? I just want to be sure there is nothing I could do my end before driving it back to the specialist (who isn't local so not easy to get home from).
Martin
Martin
