- Joined
- Dec 28, 2006
- Messages
- 377
- Points
- 168
High guys,
hoping you guys can help, used to have a stilo and you were always on the ball when it came to that
So hoping you can be as helpful with our guilietta.
Last week it came up with a egr code on multi scan ecu so i got the egr cleaned, also the start stop system was failing and a relavant code was thrown up for that at the same time. I replace the neutral position sensor on the gearstick as the wires had broken, plugged it back in to multiscan to clear the codes and get rid of the engine warning light on the dash to then get another code thrown up of p1305 neutral signal learn.
I was thinking it was the start stop sensor that i had replaced but on typing the code into google some paces are suggesting crankshaft position sensor and others are suggesting egr position sensor.
I think it maybe a coincidence they all happen around the same time.
I have searched the Alfa forums but cant get any sense out of them. so hoping you guys can help.
Still got my Panda Mk2 that i use most days and never does owt daft like the ALFA.
