Hey there guys , good evening! I wanted to ask for some advices,help. I have a Grande Punto from 07'
Can someone make a photo of how the lambda sensors are connected? I put two brand new one's from Bosch . Perhaps , because of the connectors are the same I have put them the wrong way around. The engine light does not come on ,but there are stored fault codes if red with MES .
P1141-1B , P1135-1B , P0136-13 , P010-13
Also, sometimes the car will struggle to rev up in 4th and higher gears from 3800 till about a little over 4000 , then it would just snap and accelerate like there was no problem. Note,if I quickly pop the clutch I can fully rev the engine easily , and with lower gears the problem does not appear, what could be the culprit of this? Perhaps, a starting to fail alternator? The Spark plugs are all new and same with the ignition coils (Bosch) that got recently installed. I found a guide on forums and will check the earth ground points tommorow ,because ,last but not least sometimes the steering wheel warning light comes on and says to check powersteering , although it works. Mystical "Airbag failure" notifications , random ESP messages (sometimes the traction is disabled , but restarting the car the problem goes away) , Hillstart assist not available ...
So can someone send a picture of the wiring under the air filter please? Thanks in advance!
- Year
- 2007
