General HELP!! 2019 Fiat 500 Dualogic
You will hear it clicking a bit as it shifts the gears at low speed. As you come to a stop it will select 1 and disengage the clutch. It will be the gear change you hear rather than the clutch which should be silent.
It is quite a loud click sound, and can also be felt a little if that makes any sense
Correct procedure is to leave it in gear - it gives warning beeps if you turn off in neutral (all three of mine from 2009 - 2019 have done this).
Move selector to neutral then start engine.
This is exactly what I have been looking for. Thank you for sharing your experience of parking up the fiat dualogic.
