animal91
any suggestion on people good at doing manifold mate
can some one explain itb's sorry, and j333evo saw you have a 6 speed box can i ask where you got it thanks. emailed yesterday about having block bored out, waiting for reply then if not will call tuesday thanks ben. going for a big push to get done now as lost my best mate this week and his funeral in two weeks so trying to get as much done so can drive there in memory thanks guys
Forget the ITBs
If he uses the 1.6 16v engine, there isn't any room for the standard manifold unless he wants to raise the bonnet about an inch. Then there isn't any room for an induction :bang:.
Inlet manifold curves up and over the top of the engine, then throttlebody is poking out gearbox side.
I was referring to the 1.6 16v found in the bravo/brava, stilo, and doblo.
Not a superfire engine.
As for itb's for turbo applications, the polish boys seem to love doing it with their BMW'S. Some silly power on stock internals. But they are big 6 cylinder engines, not tiny 4 cylinders.
Got ITB's on my sei and it does go rather wellit isn't a turbo though...
What size are they?
May well be easier to put the engine in the right place -- the back.
My only option now if I want to run over 0.7bar is to let my ecu take full control of the boost so boost is much lower at lower rpms and in 1st-2nd and maybe even 3rd gear
everything going **** like always the deadline moved my mates funeral was yesterday when got told had 2 weeks so car wasnt done and its failed its mot too add to problem. engine its getting there but taking its time block come back there cant bore it any bigger than 1.4 so need to get 1.6 block now so everything is f**ked up
