Hi Crystalfiat1991,
Your have not defined your expression "clutch playing up". Do you mean that the clutch is slipping under load, or is it not disengaging fully, and making gear changing difficult?
As your vehicle has a mechanically operated clutch, it will not use hydraulic fluid. Also I doubt that a three year old clutch cable will need replacing. The clutch cable could however require adjusting.
