Its Really really easy - im not prepared to go out to my car now (too cold)
Sit at the side of the passenger seat and look under the dashboard
You will see 2 main clumps of wiring
1 with be a 2pin Fan power connector
the other will be a 4 or 5 pin connector between the fan and the centre console
its usually held in place with a 7mm/8mm/Philips self tapping screws
They do vary according to lazy job in the fiat factory could lay his hands on
Anyway - Release the connector before undoing the screw
The release the screw - the resistor pack will simple come out
Refit is the reverse
IF the connector wont budge - and you can see melted plastic - its probably melted and will require a rebuilt connector
if its the common failure - then you'll be done in 15mins
ziggy
