Hello, i have a Fiat Punto 60s. The heaters in the car are not working. when i turn the nozzle to 3, it effects the engine noise. could you tell me where the heater motor can be found, or tell me what the problem is.
Do you mean the heater motor is not working or that it is making a lot of noise? The motor is under the dashboard on the passenger side; it is easy to remove. Excess noise is probably due to autumn leaves in the fan so remove and clean ; if not working usually due to corrosion on electrical connections. Let us know how you get on.
Regards,
tim
