Technical  Heater Fans
Hi Guys
I need a bit of advice, I used to have a Punto MK2 and it developed a fault where the heating fans would only blow on setting 4 at full speed and it turned out to be the resistor.
I've recently bought a 10 plate Evo and started up the car this morning and put the heating fans up then noticed that the fans were not blowing, I set the fans to setting 4 and they started blowing but will not work on any other setting
Has anyone come across this fault? Is it common? And is it easily fixed?
Hi Guys
it's the resistor pack.. - unless you've got climate
https://www.fiatforum.com/grande-punto/314051-heater-faq.html
