stephen2929
- Joined
- Apr 25, 2021
- Messages
- 37
- Points
- 69
My heater blower was intermittently not working (on any dial setting)
Which is annoying/dangerous when need continual windscreen demisting.
Sometimes it will work, othertime not working, when try to switch it on.
When works, it works on all dial settings (ie not the usual 'only works on setting 4' issue)
Lots of articles on here
eg
www.fiatforum.com
and on YouTube.
The connector and wires to the restistor pack all look fine.
The blower motor has 12v to its live side when ignition is on
(the blower speed dial connects the other side to ground or ground via resistor, when On)
Checked the switch was grounding the end pin of the restistor connection when on setting 4, as expected
ie All is as expected but blower still not working.
UNTIL
giving the blower motor a light tap sets it going
ie slightly stuck motor / worn brushes
Stopping and then restarting it will sometime start and sometime fail to start, but a light tap sets it going again.
So at least its usuable for now.
Just posting as a reminder for anyone with the same symptoms to check that first
(plus best to unplug/replug the connectors to ensure good connection, and/or visually check them)
eg
The Heater FAQ........... | FIAT Grande Punto
There seems to be a fair few questions on the forum about this so here goes.............. My fan doesn't work: After checking the relevent fuses (check handbook for fuse locations) on the s1 model the fuse is here: First things first check the fan motor... (Im pinching a few members...
UNTIL
