The fan in my wife's Fiat 500 only works on speed 4.
apparently this is a problem with the resistor pack.
Does anybody know where it is located?
Hello, Michal here.
Have beatiful Barchetta, but the case may be similiar.
To get there, you have some support, but why these resistors are failing is the clue.
My beauty had the same - just 4th speed, fastest one.
My friendly mechanic, instructed by me where too look for them ( I was concentrated on resistors) and supplied with the resistors, discovered that the fan itself was needing too much force to run - this affeced these resistors very much, asking for much current, blowing them finally. Bearings, etc., just old part. All fan has been replaced, problem is gone. These are cheap parts, I would say, very cheap, no reason to fight too long, what is worth knowing, that the problem appears after few minutes of work, not when you start it. We do not hear it usually when it comes, that's the problem.
Motor with single wiring and resistors - hm, this is so primitive... from other hand, if the fan is good, it works. Mine was 23 Y.O., I had enaugh of few things in this age too, so I don't mind
