Technical  Heater Blower Problem
scottwaddell
For the last two days my blowers have been completly dead. I was going to give the fuse a check first but have no idea which one it is. I know it is in the glove box but have checked the handbook and cant find the heater fuse. I would be greatfull if someone could let me know.
I have searched etc but can not find the answer to my question which is does any one know which fuse is for the blowers?
Take a look under the bonnet at the fuse box behind the battery, the key to fuse positions should be on the inside of the cover.
Be careful to fully secure the lid when you shut it to avoid water ingress!
Just asked the fiat dealer and the fuse to check is fuse 2 in the engine bay incase anybody else has the same problem.
Same problem with my heater, going to give this a try, thanks for posting fuse number, wouldnt have a clue.
Hope it works, or back to drawing board.
cheers
Hello I was hoping someone could help me. I have been having problems with my heater blowers since I bought the car. They come on and go off intermittently, with the help of the forum I have already discovered it the black electronic connect box that connects to the heater/fan resistor/motor. It has two burnt out terminals and the wires connecting at the other side are also frayed and burnt. The only solution I think to solve the problem would be to get new connector box and rewire?
Does anyone know where I can purchase this or have any other ideas to fix it?
Anyone’s help would be much appreciated, cheers
Hi had the same problem recently took it too fiat and they said it was the risistor and replaced it under 3 year warrante
