Ok, so I've got my relays, inline waterproof fuse holders, fuses and 17amp wires.
I've put one length of 17amp wire onto the positive connector on the alternator, and put a 15amp fuse onto it which should be enough for two 60w bulbs. Now my plan is to split down to two seperate wires which go to two seperate relays. One for dipped and one for fullbeam. After each relay output I will have two wires coming out, one for each side of the car. Now my problem is I don't know anything about the bulbs. They are H4 bulbs with three spades connectors coming out of the end. Now, I don't know which one of the three spades is for what. I've tried the multimeter but at the end of the day I can't get my head round the whole negative positive thing, especially not at this time of night.
So, can anyone enlighten me. What goes into each of the three prongs?
Now I'm guessing that the prong at the top is for negative/earth.
So the other two prongs are both positive? With different voltages going to them, one for dipped one for fullbeam. Now if this is the case, what gives the one prong a lesser voltage? And if this is the case then surely putting in 12v relays will just cancel out the lesser effect of dipped beams?
Now I'm hoping that somebody is going to say, "Don't be daft ben, you need a 12v feed to each of the two prongs, the bulb does all the clever step down stuff all by itself." Which brings me back to my origional question, which prong is which.
Anyone who can read and make sense of what I've just written is my hero, even more so if they can answer all the questions hidden in there?
p.s. If I find any of the answers myself, I'll let you know.
