Technical  Head gasket?
darlofan
I've just seen my engine coolant is below minimum and there was some oil coming out of the exhaust (it washed away when I cleaned the car).
Is this a bad sign that the head gasket has gone?
If it has how much is a replacement?
I have a Bravo Port 165 2.0 diesel.
Chris
For the moment top up the oil and coolant.
Then keep an eye on the levels for the next few days/weeks.
Report back
I've seen the websites show you which antifreeze products to add.
One final question, can I just add it as there is still a tiny bit left. Or do I need to drain the system? I'm not sure how to drain it.
Chris
You should add just enough diluted antifreeze to be between the Min and Max on the overfill bottle.
