The head is back on now, as are the inlet & exhaust manifolds, I am in the process of refitting the cambelt, but having lined up the marks on pulleys with the marks on the head & block, and the lines on the belt, I am now trying to tension the belt. The Haynes says it should deflect 90degrees on it's longest run (which I assume is between crank pulley and tensioner?) as do countless threads on here, but I found
this thread in which ycming says that rallycinq told him that there should be 1 inch of deflection in the longest run, which rallycinq doesn't deny in a later post. But having tensioned the belt I can turn it about 90degrees on the longest run, but it deflects only slightly more than 1centimetre. Did ycming mean 1cm not 1 inch? Rallycinq could you advise?
Thanks for all the help so far, on the finishing straight now!
