OP OP Keepthe12alive Member Joined Jul 17, 2024 Messages 332 Points 126 Location Fife Sep 28, 2024 #441 koalar said: Fine The little spigot on the underside of the air box is known to get block Click to expand... Cleaned that too
koalar Distinguished member Written a review Joined Oct 24, 2016 Messages 11,415 Points 2,728 Location Cheshire Sep 28, 2024 #442 Keepthe12alive said: I know brake cleaner degrades rubber, and I’m planning to replace that tube anyhow Click to expand... Don't sweat it Lots of people saying it will kill rubber First off it isn't actually rubber but a synthetic, EPDM or similar Second off, if you took the car to a garage, brake cleaner is more than likely what they would use and have been for decades
OP OP Keepthe12alive Member Joined Jul 17, 2024 Messages 332 Points 126 Location Fife Sep 28, 2024 #443 koalar said: Don't sweat it Lots of people saying it will kill rubber First off it isn't actually rubber but a synthetic, EPDM or similar Second off, if you took the car to a garage, brake cleaner is more than likely what they would use and have been for decades Click to expand... I took the drive belt off, and the noise is definitely still there
OP OP Keepthe12alive Member Joined Jul 17, 2024 Messages 332 Points 126 Location Fife Sep 28, 2024 #444 Running a heck of a lot better though
koalar Distinguished member Written a review Joined Oct 24, 2016 Messages 11,415 Points 2,728 Location Cheshire Sep 28, 2024 #445 That's good we now need to sort the squeaky noise out Doesn't come across too well on the videos Appears to me to loudest nearest the timing covers You can, just about pop the top cover off without removing anything else, not easy but doable If it's behind there it should be noticeable louder with it removed
OP OP Keepthe12alive Member Joined Jul 17, 2024 Messages 332 Points 126 Location Fife Sep 28, 2024 #446 koalar said: That's good we now need to sort the squeaky noise out Doesn't come across too well on the videos Appears to me to loudest nearest the timing covers You can, just about pop the top cover off without removing anything else, not easy but doable If it's behind there it should be noticeable louder with it removed Click to expand... I’ll have to get to that tomorrow — I’ll run the risk of making too much noise after dark Really cannot thank you enough — cannot tell you how much dread and anxiety this was giving me
