multiplani
- Joined
- Jan 31, 2012
- Messages
- 84
- Points
- 28
Hi folks, not been on for a good while due to being too busy...but need some advice...
Ok so my first Multipla (2003 115 sx jtd) has been plagued with niggles which I've sorted through, but a a few months back I started noticing a serious knocking/rattling...sounded like a big hollow heavy metal knocking/rattling type noise...when I hit the accelerator, braked, put the clutch in, turned ignition on and off, and when going over bumps...
I was concerned (sounded like a something big loose) so had the local mechanic look at it. He said it was all ok but I dont trust him and wasnt convinced he even bothered to do much looking so got under myself and wiggled and shook at everything but nothing seemed out of sorts...certainly not to justify such a serious sound...
Any way last week, pulled out of my street and 'boom'...whole car started shuddering and knocking...pulled in, called recovery...turned out to be the front gearbox mount on passenger side had catastrophically failed...gearbox had dropped considerably and was resting on other components...luckily I only had to drive about 6 feet to park up.
Turns out they are cast alloy on my car but managed to source a s/h steel one from a 2001 multipla which the mechanic fitted as I was moving house...
Got car back and it was knock free...so I thought...great all sorted...that was the problem then...
But today...same noise reappearing and the replacement mount looks ok to me...I mean its exactly the same fitment only in a steel casing...
So I'm lost as to whats causing this noise and need to sort it myself as the budget is ultra tight as I've just moved house.
Does anybody have any idea of where I should start looking? Or have you any experience with this issue...its a really heaving knocking and when switching ignition on and off it gives a heavy rattle like somethings loose, I can actually feel the knocking through the pedals when braking, accelerating, releasing clutch etc.
I'm lost? and its my first Multipla so just getting to grips with it.
