Technical Hatch wiring, switch
Corvairdave
Kamloops
Newbie here. I bought and installed the hatch repair harness for my daughters 2012 Pop. When I probe the 3 prong harness for the hatch switch, I get 5.3 volts for the license plate lights and only .35 volts for the switch feed. Any idea why so low?
The switch earth's the signal wire to open the boot/trunk I would work backwards in the loom well before it goes up to the roof line, yellow wire with green stripe if it's the same as UK spec (clip your probe((if not sharp)) to a knife blade and poke through insulation?) to check voltage
