Dear All,
I m having a problem that most of you probably have had or still having but there is one detail that is deferent so I am forced to ask for help.
Well, yes, water is leaking into the cabin under heavy rain and when I wash the car. The thing is that I m talking about this problem while having the hardtop fitted on the car.
Last weekend I used a silicon spray all over the rubbers of the hardtop and they all look in mint condition and have the required elastic ability to strongly seal the cabin from the outside world.
THE PROBLEM though is that the windows are probably adjusted in the way to firmly close against the soft top. The result of this is that when you now close the door, a gap of approx 3mm
exists between the top of the windows and the rubber of the hard top.
THE QUESTION: Has anyone removed the door panels to adjust the window tilt? If yes, could you please describe the procedure so I can have a go at it? The more details and hints the better.
Thanks once again!
Hope you and your B’s are in good shape. Take care all.
Thanks once again!
