handbrake light stays on constantly
T
Theresa
The handbrake light stays on constantly and there is also a ticking noise, which is a worse in lower gear.
HI Theresa. In regards to the handbrake light, try disconnecting and reconnecting the wire at the top of the brake fluid reservoir and then press the reset button on the top. If this doesn't fix it check the level. If that's OK then get it checked as brakes are not worth scrimping on.
Re: thanks
But it also "resets" the light after reconnection Tom. Reset, test. All good. :)
Hi Theresa,
check also the handbrake "on" switch, its usually a white coloured spring loaded button near the base of the handbrake lever, and may be stuck down. you might be able to poke at to release it with a stick or something without taking off the center console..
Owen.
@ Tom - not since I did the above it isn't mate. :)
"What's the word on the street Huggy Bear? ;)"
http://www.billhicks.com/ New Ozrics Site now up: - http://www.ozrics.com/
Abarth Valve Caps ;); Clear Repeaters; Supersprint cat-back;
Bonnet Lifters; Personalised High Level Brake Light; Starsky Cardigan :)
thanks oz light is now off!!!!!
I love it when a plan comes together. ;)
Reminded me of the old "the choke light staying on/handbag" joke. Especialy as it is posted by one of our lady members. ;)
No disrespect meant!!
Mark.
Council estate lad.
And proud of it!
Member of the Guild of Experienced Motorists.
F
7K
F1-ANG
F
A
11
308
A
E
892
E
J
1
586
Dark Lurker
