Halfords brake paint
Hammerite Smooth works just fine...(y)
proper VHT paint works but you need to do it right... needs to be 100% clean, apply very thin dustings of paint then let it dry a few hours then bake it then repeat....
easier and better to get it coated... but at the end of the day its a cast iron manifold... it will always look the same in the end... best find a nice heat shield to hide it behind
Joke is
Its Stuck on nicely around the Cat And the Actualy Manifold Bolt Area has accepted it nicely
And on the Sump too!
Its just where it all joins up :(
Took Manifold Cover off cause it was no use been on as it was more loose then anything
What "wraps" Can i get for it then? :S
Ziggy
