guide to splitting lights
S
smokedogg187
step1
remove lights..bulbs and metal clips
step2
use hot airgun to heat up all sides where glass meets plastic.be generous with the heat but not enough to bubble plastic.
step3
prise glass away from plastic(you may need help of screwdriver to start you off)remember the hotter the black gunk the better.the glass should pull away with ease(try to leave as much black gunk on the rim of glass as poss.
step4
clean plastic insert then paint.use plastic primer /colour and laquer.(i used enamel as it was a good colour match as is very tough on plastic)
step5
after paint is dry.place glass in correct possition(it doesnt matter if it dosnt slot in)
use the heat gun again genrously(heat and push heat and push)until its all fits in as it was before
step6
replace metalclips(make sure plastic has cooled abit)bulbs.and hey presto all done. fit them and smile evrytime u see them
i hope its clear enough for you
3
7K
Steve
S
J
730
J
5
851
Darren
