Tuning GSR 285 cam confusion
jamiewilson
Cinq For The Win!
Buxton
I know i'm just being stupid but wanted to check just to reassure myself...
I'm fitting a GSR 285 cam in a 1242, its a regrind so i've got top hat shims as i'll prob need to make up the clearances. I thought i knew what i was talking about until i read a thread about fitting a P75 cam where everyone was talking about using P75 clearances,
so just to confirm, i want inlet = 0.4mm and exhaust = 0.5mm +- 0.05mm ???
i measured the clearances of my current cam, starting from the pulley end:
1: 0.47mm
2: 0.45mm
3: 0.45mm
4: 0.4mm
5: 0.35mm
6: 0.5mm
7: 0.42mm
8: 0.45mm
I understand that as it wears the clearances get smaller, which makes some of these a bit odd unless they were incorrectly shimmed at some point?
Jamie
285 degrees
Lobe centres identical
Does that mean i use the standard clearances???
Nope, as a shim wears the gap will get BIGGER
I thought the gap would get bigger as the shims wear, it makes sense, but then i read in some thread that it gets smaller! But i have no idea how, and cant find the tread now!
Jamie
Nope. In practice wear on the shim itself is minimal unless something is extremely wrong. Wear takes place mainly at the valve seats.
You're unlikely -- in the extreme -- to need top hats, unless you're going for a shim under bucket configuration (a la Alfa), which is superior for high performance engines, but a PITA for maintenance.
OK, i didn't word that well, what I meant was any wear on the valve train will mean gaps increase, not decrease. And the last set of cams I took out of an RV8 were almost round :eek: god knows how little surface hardening Rover put on them
Every thing can wear, however if the clearance is too small the valve faces i.e. the exhaust valve faces a,d head inserts will be eroded.
If the clearances are too large then the can will hit the shim too hard and drop the valve from too large an opening.
If the oil is neglected or insufficient the lobes will vear and the shaft bearings.
If there is lots of grit in the engine the cam bearings and bushes will wear.
Check every time the cover is off, replace the oil and filter regularly.
Noel
