Hello everyone and greetings from Bulgaria,
Me and wife always had a dream of owning a classic Fiat 500 and two months ago we managed to achieve it. We are the second owner of a 1971 Fiat 500L with 72k km on the clock. Our tiny spicy red pepper ( named him Peperoncino ) is one of the best decisions we've made. It is a pure joy of a car - every time I tinker with it I smile, every time I drive it - a grin.
Most of the bodywork has been completed already, so we got it as you see it - Rosso Medio. Only 1 problematic spot is left and that is the shelf above the engine which has rust where water gathers through the intake vent. I will redo the carpet cause they have ruffled and faded but all the rest is ok . Got a new fuel tank -old one was leaking everywhere.
What is not ok is the unsteady idle. Honestly the car was better off a week ago and progressively got worse but still driveable.
I have tried adjusting the idle according to the manual, screwed in the throttle till it is slight faster than engine rocking, then started playing with the mixture.
I have set the rocker clearances when cold today and the car became louder but noticeably quicker - there was zero clearance on both cylinders and all 4 valves - the gap is 0.15mm on all 4 now. Had to change the gasket on both carb and valve cover - worse thing to do since the old one broke into pieces and were stuck on the head.
I have set
The problem is kinda weird the engine rocks a bit (pivoting left and right), i have changed all the rubber mounts and the spring, the old one desintegrated. I start cold with choke on and all is good albeit loud, then gradually lower the choke but BEFORE it is warm with half choke on it cuts off on traffic lights if i don't keep slight revs up. When it completely warms up with choke off - it rarely cuts off or stalls, it just feels a bit more vibratey than normal.
I think I either have not set the mixture correctly or the ignition gap ( set it to about 0.45 ).
So the questions are as follows:
- what can cause that rather rough idle (without misfires at revs)
- is it normal for the engine to become louder after the rocker adjustment, sounds more rattly than before.
Any help will be greatly appreciated.
I have set
- Model
- Fiat 500L
- Year
- 1971
- Mileage
- 44000
