GRANDE PUNTO HELP
GRANDE PUNTO HELP
Xt660wolfman
Hi
Looking for Fiat specialist in north Yorks
Have black carbon build up on top of engine and fuel leaking around injectors
1.3 multijet 2012 Van
Steve
Can you send a picture. Injectors have a seal at the base that can be changed if the engine is otherwise running OK. Its not a big job. Carbon on top of the engine sounds odd are you sure this is not oil and dirt?
Hi mate
Thanks for reply
It’s like a glossy black residue underside of air filter housing
Will send
Are the injectors a swine to remove pal
Under the air filter sounds like you have a leaky crankcase breather maybe? Shiny sound like an oil not carbon. Check all the pipes attched to the air filter box are fixed and that the box is not cracked. I had leaky injectors on a Citroen many years back. I took it to a Bosch deisel centre. Those guys were so good and it was sorted while I waited, including them recalibrating the injectors. The cost was reasonable too. Messing with the injectors is not for the feint hearted and is potentialy dangerous so maybe have a chat with a deisel centre on the phone?
