Technical Grande punto auxiliary belt noise
alfistiUK
Has anyone experienced a rubbing shriek noise from the auxiliary belt on their 8 valve Grande Punto?
My 2008 1400 8v with almost 60k has done it a couple of times, and today I noticed that it looks as if the auxiliary belt has rubbed on the top metal part of the tensioner- see photo.
The belt seems to be in good condition and has a good tension although it's about 10 years old and has done about 35k.
Apart from the odd couple of shrieks the belt seems to be running fine and the AC and alternator are working correctly.
Any advice greatfully received.
John
Please change the worn auxiliary belt and replace the automatic tensioner as it appears to be the original one. It should last a bit longer, but don't take any chances, replace with complete DAYCO auxiliary belt set. If noise doesn't go away, then it's something else like worn freewheel clutch in the alternator. :unsure:
Ok, thanks.
Hey Pal, I was wondering if you had a recording of the noise or wouldn't mind doing one and upload it? If you don't have YouTube you could direct message me and I'll get it emailed and uploaded for you. I'm trying to find out a similar source of noise also. 😁
Hi, if I can catch the noise on camera, I will, and let you know.
It's like a small electric sander rubbing noise if that makes sense. I'm fairly sure it's the aux belt slipping on the AC and/ or alternator pulleys. The belt has flapped about enough to rub and mark the top of the aux tensioner, although I couldn't see it rubbing here last time I got the noise.
It's booked in with a Fiat specialist for overdue cambelt, aux belt, water pump and tensioners soon, so hoping that cures it.
According to what you described the auxbelt rubbing against the top of the tensioner, it may be that some pulley is sticking, like it could be the freewheel clutch on the alternator. It could be doing that only when it starts idling, when clutch pedal is pressed etc.. :unsure:
Gates also do a Anti squeak belt which I have used after a garage misaligned the engine following a timing belt change 😞
Since refurbishing the alternator with a new pulley and brushes and also bypassing the noisy AC compressor with a shorter belt it’s running happy now!
