I have a problem with blower too... I can't find that 5 wires connector on mine blower. Is this because I have automatic climate controll and is maybe different?
So the problem I have is that blower is working in the morning but after job, when it is around 30 degrees celsius outside it is just not starting, do anyone know what is a possible solution? Wires on the blower looks fine F18 fuse is also fine, no more ideas.
Check the heater resistor located underneath the glovebox towards the front of the car. only real way to check is to replace but they are not expensive. Make sure you get the EXACT replacement. Take the old one out and get the part numbers off it before you but a new one. Also check the actual fan itself as they are known to blow. Get a second hand fan rather than new as they are expensive.
