I have the dreaded leaky sump problem where the steel sump pan has rusted sufficiently to become porous and is bleeding oil through it.
On looking to buy a replacement there seem to be versions listed with 8mm and 10mm bolt holes and both are listed against the same part number! So does it matter?
This is on a 1.4, 8 valve engine.
Later: Perhaps I should clarify. I removed one sump bolt and it is 8mm. Obviously this will fit through a 10mm hole, and I think would secure with a flat washer. I am wondering if the 10mm hole sumps were a modification to avoid exerting lateral stress on the sump pressing and aid alignment tolerance onto all 14 bolts, whilst still using 8mm bolts?
(I know, they are technically screws!)
