- Joined
- Jul 14, 2015
- Messages
- 54
- Points
- 20
Sorry for a repeat post, I have more information regarding my issue now, so wanted to start again. Apologies if thats breaking the rules.
So I have the common problem of the boot lock not opening electronically. I purchased a replacement lock mech and the problem still remains.
The boot light never comes on, and the bulb looks fine. Tried bridging pin 1 and pin 3 but still no boot light.
The car does recognise when the boot is open and displays the hatchback open message or boot open message (whatever it is!). So that part seems to be working at least.
Ive tested the continuity on the wires from the back of the plug to the front of the plugs contacts so i know that they aren't corroded and that thats not the issue.
Im measuring voltages and voltage spikes when I push the boot release button. Though only going up to around 8V.
I get resistance fluctuations when wiggling the rubber flexi cable that goes between the boot and the car although not by much.
Socket 1 - Measuring a little over 1Mohm, goes down to around 0.9 when wiggled.
Socket 2 - Varying wildly with no pushing anywhere between 22Mohm down to 4.
Socket 3- 260kohms up to 330kohms when pushed.
Socket 4 - 0.5Mohm up to 0.6Mohm when pushed.
Pulled the rubber flex out to have a look at the wires, though its a pretty tight fit in there from where I have repaired the washer hose by putting in a bigger guage hose to connect the two broken hose ends. From what I can see the wires look fine, no exposed areas or fraying. I suppose that there could be some in the middle of the flex but thats almost impossible for me to do without cutting off the flex. Is cutting it off a good idea? I could cut straight through one side in a line and then just clip it back over the wires once checked?
Any help would really be appreciated, im getting close to my wits end with it, all the boot is hanging out with the wires hanging!:worship:
Cheers!
Cheers!
