tinymartin
- Joined
- Mar 29, 2014
- Messages
- 53
- Points
- 72
Hi all, I have a fiat ducato 2.3 140 motorhome 2020 and I was wondering if anyone can tell me where the glowplug relay is and how to test it? Thanks in advance
The favoured one around here is Multiecuscan used with a windows laptop., alternatively Alfaobd on android. An OBD dongle will be needed. Check gendan website or do a search here for more info. These are the only 2 diy priced that deal with Fiat specific stuff.I dont have a code reader, i was looking at some readers a while ago for cars i have and the mh , i havent made a purchase yet. Do you have one you would recommend for the mh?
Hi Gerry, I have read your postings and agree with everything you have done, I have exactly the same fault on a 22 140 multijet Ducato.Hi Gerry
As you already know, glow plugs take quite a high current. That makes them more than usually sensitive to any bad connection. Sometimes merely removing and replacing a connector is enough to break the tarnish layer and make things come good. Here's hoping it's working now.
Ok Thanks Anthony, I think it coming to that, as the relay checks out ok on the bench.Hi radon
Although a cold resistance check gives some information, it's much more reliable to measure the plugs when hot, i.e. when passing a high current as in normal operation. A decent diesel specialist will have a test machine that can do this. Or buy your own tester, Sealey do the VS212 which is about £40 from Zoro Tools.
Unfortunately, glow plugs are much less reliable than glow plug controllers so be prepared to have the "odd" plug replaced if it turns out to have an internal short. As your vehicle is fairly new, there is a good chance it will come out without a struggle but they are not very "get-atable".
